Pioneer Premier same as Normal???
Burr Browns produce much better SQ than the standard D/A's
It's not quite that simple.
OK, cool, last question, how will the pre-out voltage help in or be better between the two? Thanks for the help
As I stated, according to the specifications page aswell as the owner's manuals they have identical preamplifier specs (voltage and impedance). So there is no difference there.
Burr Brown is a company that manufacturers IC's and other electronic devices (such as DAC's).
24-bit is the resolution of the DAC. It just tells you a little bit (no pun intended //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif ) about how the DAC goes about converting the digital signal to an analog signal.
Really; It's all overhyped.
Burr Brown is a good company that makes solid products. But having a "Burr Brown" DAC (or opamp, or anything else for that matter) doesn't automatically make it "sound better". And being 24-bit won't automatically "sound better" either.
For one; Burr Brown makes some 24-bit DAC's that are cheap enough that literally any product, even low-end Jensen type products, could use them. Secondly a DAC is only as good as it's supporting design.....a good DAC implemented into a poor design will have poor performance regardless of brand name or bit resolution. And even then they all have their advantages and disadvantages. There's no "perfect" way to do things.
In short; I'd never choose product A over product B based solely on product A having a 24-bit Burr Brown DAC and product B utilizing a different brand's 1-bit DAC.
Ohhh alright, but is that Preimer 3900 a good starter headunit in general now? I heard it was from a couple of ppl?
and thanks for the help all
hollowpoint
hollowpoint
NJ
Justin89T
