Pioneer DEQ-9200 3 way active, Parametric Equalizer and Universal Audio Processor
pickup1
Item(s) for Sale: Pioneer DEQ-9200 3 way active, Parametric Equalizer and Universal Audio Processor
If there's just one thing you should know about Digital Signal Processing, (DSP) it's this: It can make your car sound like a concert hall. Or a jazz club. Or even Yankee Stadium. (Or Shea Stadium — we don't care how you feel about the Yankees, we just care about making your car sound better.)
The Pioneer DEQ-9200 takes the same digital technology that makes CDs sound so terrific, and uses it to broaden the possibilities of your car stereo. When you discover just how many useful features the two-piece DEQ-9200 includes, you might decide it's the last car audio component you'll ever need to purchase. For precise control of your system's response curve, this piece offers you a 3-band parametric EQ with tweak capability at 26 different frequencies from 20-20,000 Hz!
Start with one of the six factory preset curves, adjust each one to suit your taste, then store up to 4 of your own creations in the DEQ-9200's memory. Or use the included omni-directional microphone to measure the acoustic environment of your own vehicle, and then let the DEQ-9200's Auto-EQ select the most appropriate of 3 more factory preset curves. Perfect, vehicle-specific equalization just doesn't get any simpler than that!
Been listening for the sound of recording studio in your car? Or a jazz club, stadium or concert hall? The DEQ-9200 gives you 5 user-adjustable soundfields to deliver the acoustic environment of your choice. And the Listening Position switch makes sure you always get the best seat in the house. Plus, the DEQ-9200 also gives you a built-in crossover network with variable slope. And all this is just in Standard Mode!
Switch this unit over to Pro Mode, and you trade in your soundfields for the micro-tweak capabilty that true, competition-circuit car audiophiles demand. Pro Mode is designed for use only with three-amp systems to give you maximum control over your tweeters, mids and subs. The capabilities of the built-in crossover network are enhanced,and you'll be able to edit the Auto-EQ settings, even customizing the "Q" factor (EQ curve) for each of 4 parametric bands. Plus, you'll get the ultimate, vehicle-specific soundstage enhancer — a time alignment control to correct for varying distances between each speaker and your vehicle's driver seat. Naturally, a detachable face is included, to keep this beauty where it belongs — in your car.
•3-Band Parametric Equalizer ◦6 Factory Presets (Flat/Rock/Pop/Vocal/Jazz/Soft)
◦4 User Presets
◦Nuance Control
•Auto-EQ - Auto Frequency Response Calibration System ◦3 Curves Available (Dynamic/Natural/Mild)
◦Omni-Directional Microphone (Included)
•DSP Mode (Sound Field Priority) ◦5-Mode Digital Sound Field Control (SFC) (Studio, Jazz Club, Concert, Club, Stadium)
◦Listening Position Selector (4 Mode: Front Left/Front Right/Front/All)
◦Front & Rear HPF: 50/80/125/200Hz, Level -24 to 0dB, Slope -12/-6/0dB
◦Subwoofer LPF: 50/63/80/100/125/160/200Hz, Level -24 to +6dB, Slope -18/-12/-6dB
◦Phase Switch for Subwoofer
•Pro Mode (Digital Network Priority) ◦Time Alignment (0 ~ 160", 0.5" Steps)
◦High HPF: 2.5k/3.15k/4k/5k/6.3k/8k/10kHz, Level -24 to 0dB, Slope -18/-12/-6dB
◦Mid LPF: 2.5k/3.15k/4k/5k/6.3k/8k/10kHz
◦Mid HPF: 40/50/63/80/125/160Hz, Level -24 to +0dB, Slope -18/-12/-6dB
◦Low LPF: 40/50/63/80/125/160Hz, Level -24 to +6dB, Slope -24/-18/-12dB
◦Phase Switch for High/Mid/Low
•Free-Space Controller/Display with Compact Hide-Away Sub-Chassis for Easy Installation
•8fs 1-Bit Legato Link™ D/A Converter
•Multicolor Display with EL Backlighting
•Detachable Face Security™ (with Carry Case)
•RCA Input
•RCA Outputs (x3 Pair) (Front/Rear + Subwoofer or High/Mid/Low)
•Remote Control Sensor for Optional Remote
•Super Capacity 3-Day Backup for DSP Memory
•Dimensions (WxHxD): 7-3/8" x 2-1/4" x 1-1/4"
used,nice shape
includes
brain
faceplate and mount
auto eq mic and strap
brackets
manual
Price: $200 shipped
pickup1
pickup1
Polk City Fl
pickup1
