Pioneer 12inch TS-W3002SPL or..
definitly dont get that amp, stay away from visionik, pyle, pyramid, boss, and some others. try looking into a hifonix amp that does around 1200 watts, wont be too expensive and would power that sub nicely.
definitly dont get that amp, stay away from visionik, pyle, pyramid, boss, and some others. .
gee, I wonder why so many SPL competitors use the HK boards for multi sub walls in MECA and in Db Drag? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
anyways,
a friend of mine has 3 of these in his full size, and does low 150's on a regular basis........ A teammate of mine has two of these in a wall in his ranger doing 151+......so no one should knock subs on here if they've never actually used them //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
anyways,
well i have asked about alphasoniks amps and components on here becuase i was lookin to buy and peopel told me no, there is much better stuff int hat price range, etc. and as far as the amps go, those are only for people who can run 17v amps and have hundreds upon hundreds of dollars to spend on an amp. a normal person like me and is asssuming the original poster will not get near the rated power on anything from visionik becuase they are rated at 17v, and everything in this guys pricerange is going to be crap anyway. everything you have talked about is their highest end model or close to it. correct me if i am wrong, but i am under the assumption that most of their lower to mid end products are crap. i would take lower line pioneer over lower line visionik anyday.
hmm, i seem to run my Hk board at 12 volts just fine //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
those visoniks amps are rated to power at 17 volts though, so on a normal car running at 14.4v it wont put out close to rated power.
im sure you're righter than me. Since you own so many of them and all. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The 12inch Pioneer TS-W3002SPL or the 15inch Alphasonik PSW815?? i can get either one for under 150.
Where o where can you get this TS-W3002SPL for $150!? I'm looking for another Pioneer Premier //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
solidcrowd
solidcrowd
Buffalo, New York
Cbass
