Pics of the speakers ....
blue
Since 1982
Here is the 3/4" MDF baffles the 6.5" mid bass drivers are mounted on under the door panels .... They are angled to fire the driver upwards and backwards towards the driver ..... me //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yours is the nicest SRT-4 install i've ever seen. those are some sick looking tweets. Do you have issues with seperation having the two ways so far apart from each other?
also, might want to post all the pics in your original thread, rather than having like 5 seperate ones.
2.4 liter! MAN i bet that thing is POWERFUL.. sorry just had to laugh at that...
Uh huh .... Bolt on the slicks and run under 12 seconds in the 1/4 ..... See it at New England Drag Strip during test and tune weekends ....
JMB Performance Ultimate 3" cold air intake w/ trunk mounted battery
Mopar Stage 0 computer
SAFC II piggyback
Dynoworks motor and transmission mounts
Blow By Catch Can
Mopar Stage III coilovers
All underhood ground and power wires replaced with 4 guage wire
AGP 8.5 mm spark plug wires
NGK plugs
Tial blow off valve
Mopar block off plate
Turbonetics Wastegate
Greddy Profec Type S
Breather mod and intake by-pass
BDJ Racing O2 housing
BDJ Racing 3" side exit exhaust w/ Flo Pro Twister muffler
AGP Racing LARGE bar and plate, front mount intercooler
T Bolt Clamps on all pressure pipes
AGP Racing Return Fuel Kit w/rising rate fuel pressure regulator
Walbro 255 lpi fuel pump
Psi-Fi fuel pump re-wire for higher flow
Psi Fi complete vaccuum line delete and re-route
BDJ Racing hard up-pipe w/ custom flange
180 degree thermostat
Purple Ice coolant
Cold Air coilpack lift
Centerline Storm polished aluminum rims
225 x 45 / 17 Falken Azenis Sport tires
Mopar short throw shifter with Booger bushings
Custom Work shifter mounted , AUTOMATIC Hi / Lo boost level switch by gear
Mopar billet shift knob
Progress 27mm rear sway bar
Psi Fi control arm traction bushings
Redline Tuning hood risers
Amsoil 0W-30 Synthetic Race Oil and Transmission Fluid
Mopar door sill plates
AC Schnitzer M3 wing
Coolingmist water / methanol dual stage injection kit.
Custom shift light ( programable )
AGP 50 trim turbo and RC Racing 750cc injectors
Thank you .... I probably would have problems separating the tweets like that , except for two things .... one is digital time delay adjustment , and the other is the 5 band parametric EQ ....
Id love to see proof of that, its a high 13/low 14 second car, Theres no way just slicks will shave 2-3 seconds off there time.
He has a lot more than slicks on it...
SAFC II piggyback
Blow By Catch Can
NGK plugs
Tial blow off valve
Purple Ice coolant
its all about the purple coolant
Nice install.....and yes with minor bolt ons and slicks u can run 12s....they run 13.8ish stock.....I know many people with SRT-4s and one guy has a stage 3 SRT-4 and he runs 12s all day without slicks...
Jay
Nice SRT-4... I would still take a DSM over one anyday //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Yours is nice though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Reading comprehension owns you.//content.invisioncic.com/y282845/emoticons/ready2go.gif.6557fa3d88b9eaca9c7b8efb9cbd02ed.gif
blue
Since 1982
blue
northeast
blue
