luvinthebass
hypnotize by young jeezy will just shine with your setup.sounds good to me, cant wait to test
well...ya,..its supposed to be the same width all the way back. i think if u had put the second port piece on at the end of the first instead of on the side of the first..id have been the same widthyer, Its is. Will this have a bad effect on anything ?
ok, i can change that, thanx for the advice, never new thiswell...ya,..its supposed to be the same width all the way back. i think if u had put the second port piece on at the end of the first instead of on the side of the first..id have been the same width
Yes, because when you use a screw in a panel, it creates a weak point. When you have too many, you risk splitting down the wood since the weak points are so close together.ok, is there a disadvantage of using so many screws? Ill bear this in mind for my next build
Well, that would depend on the drivers.Was merely asking if 2 x 12s would also sound good in it
Yes and no. Basically it is the glue that holds the structure together. You only need enough screws to apply pressure. Yours looks fine though.ok, is there a disadvantage of using so many screws? Ill bear this in mind for my next build
Yes ur right. I am & will take on everything on board as this has always been a little hobby of mine. thanx 4 the adviceWell, that would depend on the drivers.
To break it all down, I'd say your ability to build a decent enclosure is definitely there, but by reading some responss you have made, you need to learn more about designing a good enclosure.
Take care.
Yer is a way for yes i suppose down here. Ok I will build around the sub next time. thanx 4 the advice //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifis yer the new word for yes?
and you said
What do ya reckon,
yay or nay
32 w X 16.5 h X 22 Deep for a single 15 or 2 x 12s
TUNED TO 28hz
so there u didnt know what was going in it, so you should always build a box around a sub, not build the boxes thend ecide on subs
