**PICS** 4th Order Bandpass Build
PhatTonyDeMarco
C0CK,its whats for dinner
Well I am just about completed with my 4th order box, designed by 80 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It is for two Pioneer 12" TS-W3002SPL's, powered by a 20.1 at half an ohm. HERE is my previous build, this one will probably stay bare.
Pics in a couple minutes //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
hmm it should be loud and sound goodplay a 100hz-20hz sweep
or play something between 25-40hz
80
//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif Will do...
I changed the way you laid the box out, because there was not enough clearence for the back end of my subs. I made the subs facing the back now, instead of up how you had them (because the mounting depth) and then had to move the port to the side. I did not change the volume of the chambers, I made sure I matched what you gave me, same port and shit so I am confident there wont be much of a difference.
My edge, not perfect because Home Depot cuts my wood, but its darn close....
The front, with port attatched, and the back. I will put them in place with whether stripping and some caulk.
Here's all 78 inches of port:up2somet:
ok kooli never got the mounting dept of the subs so i guessed
box look giood really good
80
Not a problem at all bro, the plan was free so I cant complain:)
Thanks for the compliments, this is my first attempt at a bandpass and it has come out nicely IMO...
Hopefully I can get someone to help me swap out boxes tomorrow and I will let you guys know how it sounds.
Why did you use weatherstip on the final piece? My final piece goes inside (ie it is .75 shorter on all sides and fits in rather than on top) I was just going to use fiberglass to seal it. Why use weatherstrip? When I am done with the box I will pull the box out and chop it in two with an ax or cut it with a saw to get my sub.
If there is ever a problem with anything I would like to know I can just remove the back panel without having to damage the box...
PhatTonyDeMarco
PhatTonyDeMarco
West Palm Beach, FL
traksta15
