Picking RCA's
  • 5
I stay away from a manufacturer's lowest line of RCAs and stock mid-level RCAs on up. Tsunami has been really good for us. Unless you want to show off the wires you really don't need to spend any more than $10 for a 17 ft RCA or about $6 for a 3 ft. The name brands are generally a safe choice.
Same here. The lower line rcas. Just cause issues I'd rather not deal with
Double post
Which ones would u recommend buying from amazon.
970
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
980
Mike17em
Mike17em
Fontana, ca
mylows10
audiobaun
    May 19, 2024
    May 19, 2024
