Picked up my "dream car" yesterday!
ground up build... only Ford part being used will be the block, hopefuly a D1VE or anpther "thick webbed" block but any block should be good for the 600-700 horsepower mark I am planning... going forged crank, forged rods, forged pistons, aluminum heads, single plane intake, holley carb, MSD ignition, built C6 *****, 9" posi rear etc...
just hoping I can find a good standard bore 460 block...
460
forged crank couldn't find crank, but prolble $600-$700
forged rods, $650
forged pistons, $400
aluminum heads, $1500-$2000
Camshaft $ 200
single plane intake, $180
holley carb, $300
MSD ignition system $450
oil pump $73
water pump $100
timing set $50
gaskets $100
high flow fuel pump $120
dampner $400
bearings $100
plus a bunch more
460forged crank couldn't find crank, but prolble $600-$700
forged rods, $650
Camshaft $ 200
holley carb, $300
oil pump $73
water pump $100
timing set $50
gaskets $100
dampner $400
bearings $100
plus a bunch more
more like:
460 block - free
balanced, forged 514 stroker kit $1k~
aluminum heads - $1k~
camshaft kit -$200~
MSD ignition - already have
Holley 850 double pumper - already have
intake - Already have
gaskets - free
bearings - free
fuel pump - free
timing set - free
H.V. oil pump - free
as I said, my family owns a couple local parts/machine shops so IF I have to pay for stuff, it is at cost. If I need stuff that isn't too expensive, I walk into the store, grab what i need and tell them so they can re-stock it... All my machine work/balancing is free and I build myself so no labor charges... plus I have the two 351W's and 5.0HO and C4 that came with the car to sell and use that money for parts so it will actualy end up realy costing me even less out of pocket
I got the car tore down to bare bones... only issues at all are a baseball size group of pinholes in the driver floor pan, a couple golf ball sized groups of pin holes in the passenger pan, shitty rust repair in the trunk pan (they just welded flat sheet metal over the pan about 16" x 10") and the bottom few inches o fhte rear quarters...
So it is as I was hoping adn just a little sheet metal work needs done! I haven't done floors since my fox body mustang so I am lookinf forward to this! Going to just replace the entire floor pan and trunk pan the just get the lower "patch" panels for the quarter panels. everythign structural is in great shape so that is AWESOME! whoever did the "work" on this car really sucked and decided to just overlap teh sheet metal and fiberglass/bondo it smooth LOL... thank god they only did the bottom few inches of the 1/4's and the floor pans!
First thing first though I have to get a new welder since someone decided to steal my SP175 Plus... Thinking I am going to just get a Hobart Handler 187 as I have heard great things about it compared to the other brands in cimilar size...
k_schutte
k_schutte
cedar rapids, IA
Highs on bass
