ace_800 5,000+ posts
Great condition, few scratches on the left side of the amp, nothing major but overall all 8/10. 10/10 mechanical. I have only powered it on to make sure it works. ONLY reason I'm selling is cause I found the PG Xenon 600.1 I really want and I just want to recoop how much this cost. Missing 3 of the boots.
Rated at 1200rms @ 1, 2, and 4 ohms but underpowered. I don't have the birthsheet but you can expect over 1300rms. Also, the reason I was going to use it, it can pump out 2200rms+ with a simply delay. No going into the board and soldering anything. Just get a delay to make the amp boot-up prior to noticing the subs are hooked up, or unhook the subs until the amp boots up(2-3 secs) and rehook the subs up.
http://www.caraudio.com/forums/amplifiers/124912-phoenix-xenon-wiring-trick-use-own-risk-i-am-not-responsible-you-doing.html
SPECS.
•1200 Watt Power Amplifier
•High efficiency (greater than 80%) Class D Operation
•Xe.load™: optimized for any impedance load
•Xe.tune™: 24dB Linkwitz-Riley subsonic and low pass crossovers
•Xe.flow™: variable thermal feedback controlled fans
•Buffered RCA full range thru output
•Remote Monitoring Display (RMD) port
•Low Pass Level control ready (LPL-44)
•1200W x 1 (4-1 ohm)
•Built-in Crossovers
•Optional Remote Voltage Display
•Optional Remote Low-Pass Level Control
•Variable input sensitivty
•0 - 18dB Bass Boost at 45Hz
•CEA-2006 Compliant
•Dimensions: 18.25" L x 10.6" W x 2.5" H
300 shipped OBO!!
UPS
SPECS.
•CEA-2006 Compliant
300 shipped OBO!!
UPS
![DSC_0497.jpg](/proxy.php?image=http%3A%2F%2Fi67.photobucket.com%2Falbums%2Fh301%2Fxconcepts%2FDSC_0497.jpg&hash=7d8fb7b6ffb2ef29281c73dd9847588b)
![DSC_0499.jpg](/proxy.php?image=http%3A%2F%2Fi67.photobucket.com%2Falbums%2Fh301%2Fxconcepts%2FDSC_0499.jpg&hash=c8eabcc0c0c2411e7125f5b5131bc382)
![DSC_0498.jpg](/proxy.php?image=http%3A%2F%2Fi67.photobucket.com%2Falbums%2Fh301%2Fxconcepts%2FDSC_0498.jpg&hash=0e60db0d268c37dd4628ddf040a01db9)
