Phoenix Gold Xenon x1200.1 FS, get 2K RMS!!
ace_800
Great condition, few scratches on the left side of the amp, nothing major but overall all 8/10. 10/10 mechanical. I have only powered it on to make sure it works. ONLY reason I'm selling is cause I found the PG Xenon 600.1 I really want and I just want to recoop how much this cost. Missing 3 of the boots.
Rated at 1200rms @ 1, 2, and 4 ohms but underpowered. I don't have the birthsheet but you can expect over 1300rms. Also, the reason I was going to use it, it can pump out 2200rms+ with a simply delay. No going into the board and soldering anything. Just get a delay to make the amp boot-up prior to noticing the subs are hooked up, or unhook the subs until the amp boots up(2-3 secs) and rehook the subs up.
http://www.caraudio.com/forums/amplifiers/124912-phoenix-xenon-wiring-trick-use-own-risk-i-am-not-responsible-you-doing.html
SPECS.
•1200 Watt Power Amplifier
•High efficiency (greater than 80%) Class D Operation
•Xe.load™: optimized for any impedance load
•Xe.tune™: 24dB Linkwitz-Riley subsonic and low pass crossovers
•Xe.flow™: variable thermal feedback controlled fans
•Buffered RCA full range thru output
•Remote Monitoring Display (RMD) port
•Low Pass Level control ready (LPL-44)
•1200W x 1 (4-1 ohm)
•Built-in Crossovers
•Optional Remote Voltage Display
•Optional Remote Low-Pass Level Control
•Variable input sensitivty
•0 - 18dB Bass Boost at 45Hz
•CEA-2006 Compliant
•Dimensions: 18.25" L x 10.6" W x 2.5" H
300 shipped OBO!!
UPS
i had one of these and loved it... really crazy and not sure if i'd try that trick..
bump for a great amp! nobody ever has DAS BOOTS for these amps either for some reason
I know a couple that have done it for dailies. I plan on running the 600.1 as a burper. Still a great amp not doing the mod. 275 shipped
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
918
I just read the other post about this Bass Cube. IMO, it sounds like a signal leveler with adjustable Q. For that you can just use one of the many...
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
5K
ace_800
ace_800
Okinawa, Japan
ace_800
