Phoenix Gold vs. Hifonics
I have been using the PG 8.0:1 sub amp with my AA Arsenal 12 for around a week. I've had it crankin' pretty good for 30-minute spans and it has remained cool.
I did quite a bit of research before I decided to buy it and I'm happy with it so far.
so everyone here would take a Phoenix Gold R4.0:2
Over the Hifonics ZXi 6006? Even if they were the same price?
Specs
Phoenix Gold
Number of Channels 2
RMS Power (4 ohms) 125 watts x 2 chan.
RMS Power (2 ohms) ******
RMS Power (1 ohm) Not Stable
Bridged RMS Power 250 watts x 1 chan.
Peak Power Output 400 watts
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.1%
Speaker Level Inputs No
Amp Preamp Outputs Yes - 1 pair
Built-in Crossover Yes - HP / LP
High-Pass Crossover 40 Hz - 400 Hz
Low-Pass Crossover 40 Hz - 400 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 110 dB
Channel Separation N/A
Bass Boost 0 - 15 dB
Bass/Gain Remote N/A
Fan Cooled No
Fuse Rating 25A
Warranty 1-year SE
Hifonics
RMS Power (4 ohms) 150 watts x 2 chan.
RMS Power (2 ohms) 300 watts x 2 chan.
Bridged RMS Power 600 watts x 1 chan.
Peak Power Output Not Specified
Built-in Crossover Yes - HP/LP/Full
High-Pass Crossover 10 Hz - 1.2 kHz
Low-Pass Crossover 30 Hz - 150 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio >95 dB
Channel Separation >70 dB
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled N/A
Fuse Rating 60A
Warranty 1-year SE
The thing that I dont like about the PG is the small small fuse.
And sonicelectronics lists the PG R4.0:2 with the wrong specs.
so everyone here would take a Phoenix Gold R4.0:2 Over the Hifonics ZXi 6006? Even if they were the same price?
Specs
Actually, the OP was comparing two 4 channel amps. The Hifonics was 55w/ch. and the PG was about 75 i believe.
twofoolish2b
twofoolish2b
Northern, VA
psk1018dc
NorthFramingham
    Jun 30, 2026
