Sold Phoenix Gold +OUTLAW+ 1845 Limited Edition========== $799
Bricktop13
Selling My OUTLAW //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif Need the cash
It's in really good shape, pulled it from my running system. On the right edge there are two small spots where some of the anodizing wore off.
As for feedback, You can check my feedback rating on Ebay and see more pictures http://motors.shop.ebay.com/bricktop13/m.html?_nkw=&_armrs=1&_from=&_ipg=
The Phoenix Gold outlaw 1845 chassis and heatsink are constructed of brushed aluminum and finished in a gunmetal blue anodizing. In keeping with the 1840s period, the terminals, screws and the Outlaw Head logo have a chrome nickel polished finish. Based on the M100 and M50 with built-in crossovers and LPL low pass level circuitry all under the same heatsink.
This is a one of a kind amp that is in excellent condition and in perfect working order. The Outlaw is essentially 2 amps in 1, capable of powering your entire audio system. Only 1600 were made making this a pretty rare 6 channel amp!
The right corner edge has 2 spots where a small amount of the anodizing wore off.
OUTLAW Output Specs:
(M100 & M50)
2 x 100 Watts Per Channel
2 x 50 Watts Per Channel
-Bridgeable Outputs
-Tri-Linear output capacity (simultaneous stereo & bridged mono operation)
-Stereo 12dB per octave, continuously variable crossover from 30 to 500Hz
-Selectable HP, LP or Full Range for the internal amplifier and HP or LP for the external output.
-Adjustable High-Q Bass EQ (0 to + 12dB) @ 45Hz
-Pulse width Modulated MOSFET Switching Power Supply
-Stable into 1 ohm stereo or 2 ohm mono loads (*requires auxiliary cooling fan
-High-Current Triple-Darlington Output Stage design
-Gold Plated 2 Layer, 2 ounce Copper G10 Glass-Epoxy Printed Circuit Board
-Variable input sensitivity (200mV to 2V)
-Thermal Overload Protection
-Superior muting circuitry assures no turn on / off noise
-Optically isolated power supply
-VI limiting circuitry with over-current LED
-Extensive burn-in and QC testing for the ultimate in reliability
-Low RFI/EMI design
-Made in the good ol' USA
Output Power per Channel-Both Channels Driven
4 ohm @ 12/13.8 VDC
M50......50/80 WRMS
M100....100/185 WRMS
2 ohm @ 12/13.8 VDC
M50......100/120 WRMS
M100.....200/230 WRMS
Bridged into 4 ohm @ 13.8 VDC
M50......245 WRMS
M100.....500 WRMS
THD at rated power 4 ohms....0.05%
SMPTE at rated power 4 ohms
Crossover Frequencies
30Hz to 600Hz
Crossover Slopes
12dB per Octave
Bass EQ
0 to + 12dB @ 45Hz
Input Sensitivity
200mV to 2 Volts
Case Dimensions
29.25"L x 10.63"W x 2.0"H
Dimensions with Flanges and Terminal Blocks
29.25"L x 11.63"W x 2.0"H
M100 section:
2 x 100W @ 4 ohms (12.0V)
2 x 185W @ 4 ohms (13.8V)
2 x 200W @ 2 ohms (12.0V)
2 x 230W @ 2 ohms (13.8V)
1 x 500W @ 4 ohms bridged (13.8V)
Fuse: 40A (4 ohms) or 70A (2 ohms)
M50 section:
2 x 50W @ 4 ohms (12.0V)
2 x 80W @ 4 ohms (13.8V)
2 x 100W @ 2 ohms (12.0V)
2 x 120W @ 2 ohms (13.8V)
1 x 245W @ 4 ohms bridged (13.8V)
Fuse: 15A (4 ohms) or 35A (2 ohms)
Bricktop13
Bricktop13
Northern Virginia
Bricktop13
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
