PG Tantrum vs jbl bp 1200.1 vs viper d1200.1
depends on which ohm you need it for. the tantrum puts out about 1500w at 2-4 ohms, while the jbl puts out max power at 1 ohm i believe. and dont get the viper, not even in the same class as these other two amps.
The Tantrum, end of discussion.
Build quality is leagues above the other two, and you'll love the flexibility in impedance. The JBL will do its maximum power between 1-2 ohms; you won't get an increase by going down to 1.
The Tantrum is simply a better built amp.
i would need it for a sonic fx quad 1 ohm so it would need to be putting out 1200 @ 1 or 4 or .25 ohm. On roe it says the tantrum puts out 250 @ 4 ohms (12.5 volt) and 1200 @ 4 ohm (14.4 volts) . Is this the case?
birth sheets have the tantrum putting out 1400+ watts at 4 ohms //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ive owned the tantrum and the jbl and I like the tantrum a lot more. It seems to be quite a bit louder and is more efficient. The tantrum will do its power from 2-4.
get the tantrum //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif iceteebone's is rated @ 1400+ watts @4
PESteele
I wang on an 8 in a van
PESteele
annapolis
DaveT
slater
    Oct 4, 2025
    Oct 4, 2025
