PG Tantrum 1200.1
Matador
-= StillBumping =-
Are they underrated?
stated to put out 1200rms @ 2ohms, but i was loooknig at the specs, it has a 80A fuse, n it's around 70% efficient, so if P = VI, 1200 seems quite a lot unless they up the voltage internally.
i would love ot see the birthsheet for this one if anyone has it?
Many fuse ratings don't work out right if the amp is indeed putting out its rated power. Duty cycle has a lot to do with it, ie the amp is drawing more than the rating of the fuse but not for long enough to blow it. Consider also that the tantrum amps are rated at 14.4 volts IIRC.
seen 2 birthsheets:
1 was 1502 w
other was 1509 w
a tad underrated //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I love PG amps for a reason, and the Tantrum line has done very well
Im becoming a PG freak also . Bought a 600ti Amp . Love it . Just bought to PG Ti10D subs WOW amazing . Hmm Maybe I will just go buy the Ti-elite comps also an have a enitre pg set-up //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Matador
-= StillBumping =-
Matador
Ca
limitkid7
