PG Tantrum 1200.1 VS JL 1000/1
I would say the JL is a much better amp. I have had great luck with them and love the way they sound. I havent had good results with any of the newer phoenix gold amps.
the tantrum isn't a new pg amp //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif if you were comparing it to the xenon, then i would go jl. the tantrum is a nice amp. reliable and do about 200-300 watts over rated power
I didnt say new, I said 'newer' as in after mps, ms, zp series, etc. nor did I say they were bad amplifiers. I would recomend a 1000/1 over a tantrum though, especially if money is not a problem
the 1000/1 will give u exactly what u ask out of it. Nothing more nothing less, the pg will definitly give you more power, but the JL puts out its the same power at different ohms, so if you decide to switch subs in the future, vc configs arent a problem.
If you only need 1000-1100watts and the money isnt a problem, go with the JL
If you want the extra watts and are set on your sub, go with the pg.
the tantrum puts out the same power at 2-4 ohms //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
having owned both amplifiers... i've SEEN that my JL 1000/1 kicked the crap out of the PG. i always thought PG was overrated, while the JL puts out well over 1k. it easily keeps up with a kicker kx1200.1, or sx1250.1... FYI
i'd say if money isnt a factor go for the JL.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
to each his own... but i'm guessing you've owned both too right???
I have betta tested several amps, and these 2 I have on several occasions. I guess we will have to agree to dissagree though. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
JL12W7INAGS300
CA's Most Hated
JL12W7INAGS300
Oklahoma City
Towncar
