PG Tantrum 1200.1 specs
1ohm stereo is fine.1ohm bridged is not.
That doesnt mean it wont work in 1ohm mono, im shure you could do it with very little volume with no problem
YOu put serious risk frying the amp runing it at 1ohm mono. It runs warm at 2ohms as it is. Play it safe.
How would this amp compare to BXi1606(power wise)??
you can't reallistically compare the 2. the hifonics is rated at 1 ohm/1600. the gold is 1200 underrated/2-4 ohms. it depends on what sub/subs you're running on it. if you need 1 ohm stable then the hifonics is it. if you're running sub/subs at 2-4 ohms then the pg is it.
jrouter76
jrouter76
jrouter76
Mount Vernon ,Illinois
tat2
