PG RSD's dont sound good when turned up.
Tearlessj
Ok Im running the PG RSD 65cs in the front and the PG RSD6.5 coaxial in the back. All powered by a Alpine MRP F550.
RMS Power @ 4 ohms: 4 x 90W RMS (4ohms, 14.4V, 0.08% THD)
With the gain set at 0 front and rear. Frequency set at 45 for the front and 65 in the rear. When I crank my headunit all the way, it sounds like its distorting a little. I know some guys pushing way more power than this. Why do mine do this? Any settings i should mess with?
Don't turn your headunit all the way up //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
1 you answered your own question
2 the volume knob, button
set your HU volume to about 3/4 and then turn up your gains untill they distort or they are loud enough, set your frequency at like 60Hz and see if you can stand them at 80Hz for both of them, they are being crossed over around 80-100Hz when you see people pushing 150 to each speaker.
I gave mine (actively) 75w to the tweets, 100 to the mids, no problems at all. I have friends that are pushing way more then that to them w/o problems. My initial thought was w/the majority, set the HP at 63 Hz at a min of 12 dB/oct.
I bought a set of Dynaudios for $100. Does that mean they don't sound good. *Store closed the doors*
Some people need to get over that "I paid more so mine's better" mentality.
The xover is the week link in that set. That's what is limiting the power you can give them. BUT, it will still take more then what it's rated for. All in all, you're xover point was to low. That's the real reason why.
Tearlessj
Tearlessj
Memphis TN
Slammed
