PG RSD vs Fi Q vs IDmax
Which configuration?
  • 2 PG RSD12s sealed
    Votes: 0 0.0%
  • 2 PG RSD12s ported
    Votes: 1 12.5%
  • 1 Fi Q ported
    Votes: 1 12.5%
  • 1 IDmax ported
    Votes: 5 62.5%
  • OTHER
    Votes: 1 12.5%
  • Total voters
crosjr
I currently own 2 PG RSD12s (dual 4), 1 Fi Q 12 w/BP (dual 2) and 1 IDmax 12 (dual 2). I have a sealed enclosure, about 1.4sq ft volume. I had the IDmax in that box in a little Hyundai Accent hatchback and it was perfect. Now I have moved to a Mazda 3 with a trunk and it is not near loud enough for me. Before I was limited by lack of trunk space, however now I have more room and can look at more options. I would like to use the subs I already own. They would be powered by an AQ1200.
So which configuration would you guys suggest for the max volume while keeping the sq of the subs? I honestly know barely anything about ported boxes, so if you vote for a ported option could you give me sq ft and port ideas?
I couldn't figure out how to edit the poll but please ignore the 2 PG ported option. No way will I have room for that box.
nonsense. Go to the RE website and click on the box calculator. Then play with the dimensions and you can get an idea of how big you can go
RE calc can be very inaccurate...
OP if space is an issue when running ported you could try out aero ports
crosjr
crosjr
Tampa, FL
Buck
