performance for my mustang...
You need a Manual.
Autos are sooooooooooo close compared.
Also Manuals get better gas mileage.
IMO, since I have a 94 Mustang GT and know the car inside and out, theres no really good "bolt ons" that will see buncha of power for alittle bucks.
JLT coldair intake is prolly a good one. Plus it gets rid of the ugly *** stocker.
Also, I wouldn't put Dynomax on it either. Ones I've heard with em, didn't sound pretty.
IMO, get the Aluminized Bassani, they cost a little more than the Flowmaster Cat-back but make more HP and sound better to boot.
The 5.0 gives you quite a few options. I would port and polish heads, intake, headers, exhaust (i like borla mufflers better than flowmaster btw)
cam, gear set, possibly even swap heads to a performance head, eventually supercharge it
possibly bore out the motor some to gain some displacement
there are a ton of parts for 5.0s and many ways to make power. even seen a few with carburetors instead of fuel injection, so your options are endless
That was my old mustang a 1993 w/ a 414 and a t-56 6spd...
short tube headers
H or X pipe w/ or w/o cats
flowmaster mufflers
CHP spyder intake
accufab TB 75mm
lightning MAF 90mm
anderson power pipe
AFR 185 smog legal heads
crane cam
30lb fuel injectors
MSD distributor
msd 6al
msd cap
msd coil
taylor 409 wires
3:73 or 4:10 gears
UPR or maximum suspension depending on if you want to carve corners or straight line...
Then take your ride to a dyno shop and have them tune it and burn a custom chip for you, the generic chips are a waste of time and money...
with that combo you are looking at 320-330rwhp and around 330-350lbs tq...
And if you plan on adding nitrous to your car, you will have to get a nitrous grind cam...
95 is the last year for the 5.0. I would forget the MSD ignition kit..on a bone stock to mildly modded engine its totally a waste of money. The Stock ignition is totally fine. The chip...ehh money would be betetr spent else where like on the gear swap. 3.73's and 4.10's would be fine but get a shift kist to help the ***** stay cool. After that i would find a set of Gt40 aluminum heads used..look around on Corral.net or stangnet.com they are out there. Get a set of 1.7 ratio roller rockers,70mm throttle body and a good quality cai...like a JLT.
pitbull12887
pitbull12887
waxhaw, NC
pitbull12887
