PDX 4.100 or 2.150
RoachForLife
$65 more for the 4.100 over the 2channel. Although Im only using the 2 channels right now I was thinking might be good for down the road? I dunno, help sway me one way or another. Is it just throwing $65 away or what? Going on a set of PG RSD65cs
Thanks
i say go for the four channels as it'll give you more flexibility down the road if you were ever to go active or if you were going to bi-amp some components. but also that $65 will also give your more power when you bridge the amp into two channels, so in a sense, that $65 will not go to waste.
Go with the 4 channel, it's not much more and it's better not to regret it in the future. Plus you can always bridge the channels if you only want to use 2 if you ever wanted to
RoachForLife
RoachForLife
Florida
jdawg90
