patching holes in mdf?
local hardware store has them..at my resturant we poured epoxy on the bar so it had this clear finish coat on it like a big thick layer of sealer....sec i'l get u a nice link but ur local stores always have this ...even walmart http://www.aplusbputty.com/applications.htm
e-poxy>all glues
Oh, lol I fail, I know what epoxy is, I thought the way you wrote it (e-poxy) you were talking about a specific kind
Loctite epoxy is nice, its what I use for my recones
With a hole that size, I would not use sawdust and glue mix. Instead, get a dowel pin the same size diameter as the hole, cover it in glue, shove it in. When the glue is dried, trim off the excess of the dowel. Best way to do it IMO.
Very good idea, I never would have thought of that, +1 for joo //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Why does liquid nails ****? i read good things about it on here before and i used it to seal up my first box i built //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I know it is good for bonding 2 things together, but I don't know how well it would work for filling a hole.
For sealing seams it is fine, for any type of adhisive/patching purposed it doesn't work well. It does not soak into the wood and create a chemical bond like wood glue does, only a surface coating. I made the mistake of building my first box with liquid nails back when I didn't know jack shit about car audio and the box blew apart on 800rms.
im running about 1200rms, and i also used a shitload of screws in the box too. I used gorilla glue in the seams and went along the inside edges with the liquid nails. Ill see how it holds up i suppose
gorilla should be fine especially with screws, but I don't believe it has the bonding abilities of wood glue.
could be wrong
I have to agree with BJ on this. If you don't have dowels you could countersink a 1/2 or 3/4" screw in the hole and putty over it.
Lil Poot
you sturrin at me brah?
Lil Poot
Wichita KS
Lil Poot
