patching holes in mdf?
is this better than wood filler putty?
I would assume so seeing as the glue joints are supposed to be the strongest parts on the box, so I think the same would be true for a sawdust/titebond plug, this is the way I have always done it. The putty doesn't bond to the mdf and soak in like the glue does so it seems to me that high enough pressure on a putty plug could blow it out of the hole, I have never used putty before though so I can't say from personal experience.
No specific measurements, just make it thick and lumpy, kind of like the consistancy of cookie dough, then pack it into the hole as tight as you can, after that put a few extra drops of glue onto the top of the plug so it can soak down into the mixture and the surrounding surface wood.
why not just glue a small piece of scrap MDF over the hole...
He wants it to look good
Doesn't bond to the wood
put a peice of mdf inside the box covering the hole
Wouldn't cover the hole on the outside, again he wants it to look good
liquid nails //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You fail, liquid nails sucks
Lil Poot
you sturrin at me brah?
Lil Poot
Wichita KS
Lil Poot
