Passive radiator question
mcsoul
such is life
Does the passive radiator need to "unload" into the cabin?
In other words, lets say I had 2 or three Boston g5's running sealed
and walled off in a trunk car. The g5's obviously unload directly into
the cabin, but are sealed off from the rear of the enclosure. For the
sake of argument, each sub has it's own 1 cubic foot of air space.
Now lets say I add the required compliment (2 or 3) passive radiators to
the back of the sealed enclosure, remember, the back is walled off from the
cabin.
Now will this setup get the full benefit of the passive radiators, partial benefit
or no benefit?
This is more of a conceptual question to help me understand the mechanics of
the passive radiator. I'm not really thinking of doing this.
Also, for bonus points (jk), if you know; can the passive radiator unload into
almost no airspace, say firing into a sealed off spare tire well with no escape
of air and very little air space to load against outside of the box?
-thanks
cabin.
or no benefit?
-thanks
It's simply actually. A passive takes the place of a port, so your install options are just like a bass reflex design. Now, ask yourself if placing a port in those locations will benefit you?
Best,
Mark
it can unload anywhere... doensnt need to be in the cabin
How would that help? Persay its unloading into a sparetire well, wouldnt that just change the pressure inside of the box? does the passive radiator work by helping the sub travel further in a sealed box?
Best,
Mark
So your saying that the passive basically acts like a port. The conditions I gave
would be very adverse (bad) in a ported configuration. So the Passive radiator
creates it's own sound wave similar to a port and therefor needs a nice wide
path to the listening area. Correct?
This is basically the opposite of what Dcole18 said though.
Yes, a PR behaves in a very similar manner to that of a port. The PR's output is summed with the driver's output, so the positioning of the PR must be done so as to maximize the summed output. There is no real reason to have the PR oriented so that none of its output enters the listening area.
mcsoul
such is life
mcsoul
dfw
wu501
