PAS Mag Review of PowerBass Xtreme XAX-1200D
Could someone please post the output numbers for this amp (PowerBass Xtreme XAX-1200D) if they have the article hanging around some where. I checked the website but it looks like they only archive the text of the article.
Thanks!
XAX Series Monoblock Class D Mini Car Amplifier
RMS Power Rating:
4 ohms: 400 watts x 1 chan.
2 ohms: 700 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
MAX Power Rating:
1 ohm: 2400 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Philips/NXP chip set with double sided copper plated PCB
Wired remote gain level control included
LED power (blue) and protect (red) indicators
Variable Bass Boost (0 to +18 dB bass boost at 40-100 Hz)
Virtual silence turn on/off mute circuit
High damping control circuit
High efficiency SMD circuit technology
Ultra low current draw with more than a 85% efficiency rating
Dual link power doubling circuitry
Mono channel operation
Speaker-level inputs with signal sensing for automatic turn-on
Blue LED logo, power and speaker terminal lighting
Preamp RCA outputs to daisy chain multiple amps
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink with induction cooling fan for extreme heat dissipation
Platinum-plated Tiffany RCA level inputs
Platinum-plated screw terminals
Input sensitivity:
Level: 500mV-6V
Variable low-pass filter (25-250 Hz, 12 dB/octave)
Subsonic filter (10-50 Hz, 12 dB/octave)
Phase Shift: 0-180°
Damping factor: >200
Frequency response: 20-250 Hz
Also found as: Power Bass Xtreme XAX-1200D
Dimensions: 14-5/8"L x 7-1/16"W x 1-15/16"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Authorized Internet Dealer
1-year Manufacturer's warranty
Its called Google fella. If you want to find info on something, do it yourself. If you absolutely can't find any info on that amp, than come here. Lazy a55 people
and that would be why I'm here...
If you'd take a sec to read what I wrote you'd see I am looking for the output specs from that specific article which I don't have and cant find reposted. They have the article on the website yes but not the numbers they got like in the actual mag article. Just curious if someone had that issue of PAS mag laying around.
KnightWhoSaysNI
KnightWhoSaysNI
Oregon
KnightWhoSaysNI
