Could someone please post the output numbers for this amp (PowerBass Xtreme XAX-1200D) if they have the article hanging around some where. I checked the website but it looks like they only archive the text of the article.
Thanks!
XAX Series Monoblock Class D Mini Car Amplifier
RMS Power Rating:
4 ohms: 400 watts x 1 chan.
2 ohms: 700 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
MAX Power Rating:
1 ohm: 2400 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Philips/NXP chip set with double sided copper plated PCB
Wired remote gain level control included
LED power (blue) and protect (red) indicators
Variable Bass Boost (0 to +18 dB bass boost at 40-100 Hz)
Virtual silence turn on/off mute circuit
High damping control circuit
High efficiency SMD circuit technology
Ultra low current draw with more than a 85% efficiency rating
Dual link power doubling circuitry
Mono channel operation
Speaker-level inputs with signal sensing for automatic turn-on
Blue LED logo, power and speaker terminal lighting
Preamp RCA outputs to daisy chain multiple amps
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink with induction cooling fan for extreme heat dissipation
Platinum-plated Tiffany RCA level inputs
Platinum-plated screw terminals
Input sensitivity:
Level: 500mV-6V
Variable low-pass filter (25-250 Hz, 12 dB/octave)
Subsonic filter (10-50 Hz, 12 dB/octave)
Phase Shift: 0-180°
Damping factor: >200
Frequency response: 20-250 Hz
Also found as: Power Bass Xtreme XAX-1200D
Dimensions: 14-5/8"L x 7-1/16"W x 1-15/16"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Authorized Internet Dealer
1-year Manufacturer's warranty
