parallel wiring on subwoofers
Just run one set of wires (positive and negative) from each sub, then hook both the positives and negatives together into your amp...
Or you can run a set of wires from one woofer to another, then another set from one woofer to your amp, either will work.
Ok thanks for the help, I just wanted to make sure before I hooked it up. I want to make sure all of my wiring is right the first time through.
Skeeter51
Skeeter51
CANTON
Skeeter51
