Ok, I just have one more question about setting up my system with the new amp I bought. Just to run through one more time, here is what I have. A pair of 4" mids and 1" tweeters in the dash, 5.25" woofers in the doors, all powered by a JBL 40w 4 channel amplifier.
Now I'm wondering if I can wire the 5.25" woofers in parallel for a 2 ohm load, which the JBL would then put out 80w. So I'm thinking of setting up my system one of 3 ways:
1) Keep it the way it is, 4" mids and 1" tweeters using the 2 front channels, and the 5.25" woofers using the 2 rear channels for a rated 40w to each channel.
2) Have the 4" mids and 1" tweeters wired normally using the 2 front channels, getting 40w to each channel, and wiring the 5.25" woofers in parallel using one of the rear channels for a 2 ohm load, 80w.
3) Wiring the 4" mids and 1" tweeters in parallel using one front channel and wiring the 5.25" in parallel using one rear channel.
I don't care if I lose the fade and balance option on the radio since I never use these anyways. Out of these options which would you recommend? I'm thinking option 2 might be the best, since I could at least keep the dash speakers in stereo. Am I way off base with my ideas? Thanks.
