Sold (Pair) Phoenix Gold Titanium Elite Ti12D's
audio_phill
Walking TSP Encyclopedia
1. Product: (2) Phoenix Gold Titanium Elites
2. Specs: Rated for 1200 rms, I ran 1 one my 5 in 2.76 @ 25Hz on 1600 Class A/B Watts for
4 years and it's as cherry now as it was outta the box in 2003.
3 @ 20Hz has an f3 of 17Hz and plays flatter than any sub should from
19Hz to 60Hz. Exceptional realism in low and sub harmonic frequencies and
4" Mechanical 3" Linear P-P which is illuminated for emphasis is darn hard to beat.
TSP's are: (From woofer on Left)
Re = 5.7300 ohms
Fs = 35.4496 Hz
Zmax = 49.0864 ohms
Qes = 0.8147
Qms = 6.1643
Qts = 0.7196
Le = 4.0262 mH (at 1 kHz)
Diam = 248.9200 mm ( 9.8000 in )
Sd =48664.1824 mm^2( 75.4296 in^2)
Vas = 17.3432 L ( 0.6125 ft^3)
BL = 24.7495 N/A
Mms = 390.9954 g
Cms = 51.5521 uM/N
Kms =19397.8457 N/M
Rms = 14.1279 R mechanical
Efficiency = 0.0891 %
Sensitivity= 81.5173 dB @1W/1m
TSP's from the one I've beat on for since 2004 (Fully Broken In):
3. Description/Condition: BNIB, never powered, mounted, not even a hint of dust!
Ship in factory double boxes with all original paperwork and stickers. All 4 of the new
Ti's were made in the same month.
4. Price: :$260 per + Shipping (18 x 18 x 15 and 48lbs)
5. Pictures:
For the tech guys, heres a run down of the build details
* Composite Anodized Aluminum Flat Panel Diaphragm, Made of a skin of 22 GA 80 grit grained aluminum with a matte gray anodizing. This is sandwiched together with a high density lightweight gator foam. The combination provides an ultra strong well damped flat panel diaphragm.
* Large Roll Rubber Surround Assembly. The surround was designed to provide a full 3 inches of linear peak-to-peak travel with very low distortion.
* Black Anodized 3" former with 2 layers of nomex spunlace for ultimate wicking of epoxy adhesive.
* Custom tooled cast aluminum basket. This structure was designed to provide the ability to build a speaker with up to 4" of peak-to-peak excursion. Another key design goal was the ability to have key design goal was the ability to have user serviceable diaphragms. The Ti12d Elite basket accomplishes both these goals perfectly.
* built in venting for internal basket back pressure and improved cooling
* Spider assembly clamp screws: Removing these screws releases the Spider assembly for in field service.
* Computer optimized low carbon steel top plate.
* Cast aluminum heatsink provides heat sinking for the motor assembly for efficient cooling.
* Kevlar reinforced pulp cone: The combination of materials makes for an extremly stiff, lightweight cone diaphragm.
* Custom tooled injection molded spider spacer with integrated Venting. This allows the spiders to be separated by 1.5" and provide perfect alignment at all excursion levels.
* Surround Clamp Screws: By removing these screws releases the surround assembly from the basket.
* Large 4 layer aluminum 3" voice coil for massive power handling.
* machined aluminum cooling ring surrounds the voice coil and wicks the heat away to be sunk into the massive motor structure.
* Triple stack huge 235 oz ceramic 5 magnet.
* Computer optimized low carbon steel Back plate.
Wow. I've always wanted a pair. Looking for trades? Bump for you (wicked)...
Only trade(s) I need would be an Audiopulse LM10D2 (preferably new)
low end monster sub. If I didnt just buy an audiopulse Axis i would jump on one. what voicecoil config are they?
Dual 2 ohm coil (TSP's show actual Re)
usps shipping to canada for a pair? s6j1b3
18 x 18 x 16 45lbs from 24311.
Other trades that I'd be interested in. Audiopulse LM10D2's, Older TC Sounds drivers (TC2, TC2+, TC3HP, TC7, TC9, etc, RE XXX, Eclipse 9102's, Exodus Maelstrom, CSS Subduction 15, I'd trade for good amps as well, like Eclipse 7232, Van Gogh 1600.2, 800.2, 600.2, 400.2, 320.4, Hifonics Andromeda's XIV 125 or larger, Hifonics XX Colossus (not colossus II) or XXV Colossus, XX Zeus, Jupiter, Chaos.
I believe My Homie is ging with my pair of Solo X 18's instead of the 4 Ti12D's. So, any interestlet me know, will split 1 pair and one pair to be sold as a pair. 250 per plus shipping or $475 plus shipping for a pair (5 total Ti12D's for sale, one used, 4 BNIB never powered)
audio_phill
audio_phill
Small Town VA
audio_phill
