PA DB521 vs 5251 - Need help getting front stage actually in front of me!
Doc_Jim
VA
Greets.
Short of it: Jeep Wrangler. PA 521's in front....PA 651s in soundbar (right behind driver/pass...above head).
Basslink in the back.
Sound Ordnance 4050 amp (4x50)
KDC 897 HU
Perhaps due to the fact Wranglers **** for audio? I have to really wreck the amp gain and crank the faders in order to get the stage in front of me.
If I run front gain at like 85% and rear gain at like 50% and then put faders 35% to the front.....it mostly puts things in front of me.....but I am sacrificing a lot of 'volume' to run this way.
Anything shy of the above and the stage is behind my head :-|
Im no expert (or anywhere even close)....and I know this isnt a high end setup by any stretch....
Any advice on how to correct this? Would crossover tuning affect this? Insight from you guys?
I was thinking changing the fronts to DB 5251 components might help? With the separate tweeter and such?
Wranglers **** for audio. I have not had a chance to try them, but you might want to try Q-Logic kick panels if they're available for your body style. They need to be cut to fit your speakers, so you could try them with coaxials at first.
thx. WIll look into that. I know they are sh*t for audio.
I feel like if I can just get enough power into the fronts, and maybe with separates as well............then it could work.
Maybe if I went to 4X100 amp.....then trimmed the rears down enough so the fronts were present? I would then still have plenty of headroom.
This approach now, with 4x50 cuts out too much power.
Will check those panels. Thx.
Doc_Jim
Doc_Jim
VA
Doc_Jim
