PA amps
FLYNNT9
i read more then post
okay i need another amp for my work car , i was wondering what people think about the PA LT 1920 and the new plasma series version of the 1920, same rms stats.440 @2ohm ,370@4ohm x2 . both can be had for about 150-165 , also i'll take any suggestions on other amps in this power range , i got $200 loose dollars to spend on a budget amp. also i was looking at the hifonics tx 1505 anybody ever use these i think its a budget bx 1500 for about $200.
profile is the reason i need another amp my cl600m died on me yesterday so no more profile for me . maybe for my interiors not my subs . my temp. amp RF 200a from way back is holding me for now ,but since u guys say there pretty good ill order one . how are those mono amps if they are that much better i can spring for the 1000d or which ever is the entry model
I have a LT-1440, good amp. For the money, theres no match. I've been considering getting a 1920, LT or the Plasma one, but I'll probably get the 3000db, its only about $120 more if your subs can take it.
I believe you would be very happy with the LT 1920. You should also consider the D-Class series amplifiers from Power Acoustik. I'm running (2) A3000Db's. When it comes to Power vs. Price you can't really shake a stick at the D-Class series from Power Acoustik. You won't be disappointed at all.
FLYNNT9
FLYNNT9
Poughkeepsie , NY
Goldtaz1
