Pa A3000db
x2 i have to say around 2k
Not buyin' it. I know that one mag article got it at 2300w, but I don't even think they accounted for clipping. Plus - it's basically the same board as the Optidrive 2000D which is 1900w at 1/2 ohm. 1600@ 1. I'd bet 1400ish at 1.5.
you do realize that these amps were meant for burping not intentionally for daily use unless set correctly //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thats right, because i can tell you first hand a single pa 3000db of mine tested on a quad dd 9915 surely didnt have a problem at .5 load for a solid 5 minutes. Its a solid amp and the lanzar opti series is the best amp they offer. My guess is it would give you 2k at 1.5 ohm load, but I dont understand why you cant drop it to a even 1ohm load?
stish05
stish05
clintonville, wi
Mr. Loki
michigan born
    May 14, 2026
michigan born
    May 14, 2026
