Sold pa 5500, 4 channel, components, and 4 15s
cthedinger
Pioneer TS-D720C 6-3/4" Component Speaker
$80 plus shipping
•Dual-Layer IMX Aramid/Basalt Fiber Composite Cone
•Butyl Rubber Surround for Smoother Response
•Glass-Imide Voice Coil Bobbin
•Wire OFC CopperVoice Coil
•Conex Damper
•1-1/8" Soft Dome Tweeter with Magnetic Fluid and Neodymium Magnet
•Watts MAX. Music Power: 260 Watts
•Watts Nominal Power: Handling 60 watts
•Frequency Response: 30 Hz to 33 kHz
•Sensitivity: (1W/1m) 88 dB
•Ohm Rating: 4
•Mounting Depth: 2-1/2" (64.5 mm)
•Cut-out Dimensions: 5-5/8" (144 mm)
•Speaker Grilles Included
and the speakers are 6.5 inch compatable
TSD720C TSD-720-C
The amp
Pioneer GM-6400F 4 Channel 600 Watts Car Amplifier
$100 plus shipping
•GM Series 4-Channel Class AB Car Amplifier
•RMS Power Rating:
◦4 ohms: 60 watts x 4 chan.
◦2 ohms: 75 watts x 4 chan.
◦Bridged, 4 ohms: 150 watts x 2 chan.
•Max power output: 600 watts
•PWM Regulated MOSFET power supply
•LED power indicators
•4/3/2 channel operation
•Built-in crossover LPF/HPF (front/rear independent)
•Variable high-pass filter (cut off frequency: 80 Hz, -12 dB/octave)
•Variable low-pass filter (cut off frequency: 80 Hz, -12 dB/octave)
•Built-in speaker level inputs
•Hi-volt (400mV ~ 6.5v) input level control
•Exclusive H shaped chassis and heatsink
•Gain control caution feature helps prevent damage to speakers
•CEA-2006 compliant amplifier
•Frequency response: 10-50,000 Hz
•Dimensions: 8-1/2"L x 2-1/2"W x 13-5/8"H
everything has only been used for about two weeks have the boxes for everything but one pair of speakers
i am selling this stuff because i am picking up a chrystler new yorker this week and decided to go with a whole different set up
Gothic Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 1700 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 3200 watts x 1 chan.
Max power output: 5500 watts
MOSFET power supply
Wired remote bass level control included
Bass Boost (0-18 dB bass boost at 45 Hz)
180 Degree phase shift
Pulse width modulation circuitry
Mono channel operation
Bridged Synchronization (strap amps together to double power)
Preamp RCA outputs
3-Way system protection circuitry (short, thermal and overload)
Gunmetal gray anodized finish with chrome accents
Heavy duty aluminum alloy heatsink
RCA level inputs
Screw terminals
Low level inputs (200mV-8V)
Variable low-pass filter (40-200 Hz, 12 dB/octave)
Subsonic Filter (12 dB at 20-50 Hz)
Frequency response: 15-150 Hz
Dimensions: 19-1/8"L x 10-5/8"W x 3"H
1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
$190 plus shipping
and i have 4 qpower deluxe series 15s that are about two months old for $70 plus shipping per sub
cthedinger
cthedinger
Inglewood, CA
jdmferio13
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
