Oz Audio 12.1 Power??
RetroAudioinc
Custom Car Audio Decals
Any one every used one of these Oz Audio 12.1 Power?
How do they sounds?
How much power can it take? ( they rate it at 4000wrms 8000wmax ) I don't think so.
How are the lows on these good or bad?
I searched google but did not see a lot since oz is gone. I did find there manual here.
Info from OZ Audio's old site:
- 12" Power Series Subwoofer
Multi-layer, 1 inch tall ripple formed foam
surround to match spider complaince
Black glass fiber / PMI sandwiched cone for
maximum strength
Die cast aluminum basket with heavy epoxy
powder coating provides rigidity for increased
motor assembly alignment
Quad 1Ω, 4-inch copper clad aluminum wire
voice coils coated with high temp resin for
optimum reliability and power handling under
extreme conditions
Kapton reinforced neck joint
Black anodized aluminum former that enhances
voice coil cooling
Computer optimized, double stacked 230 oz.
high indensity ferrite magnet assembly that
maximizes power transfer and handling
Chrome plated and engraved back plate design
with integrated vent radii for superior cooling
and maximum magnetic force
Custom black aluminum dustcap
S/P* S/S**
Diameter 12" 12"
Impedance Quad 1 Ω Quad 1 Ω
Fs (Hz) 37.73 37.73
Qts .397 .455
Vas (L) 21.51 21.51
Qes .431 .5
Qms 4 4
Cms (uM/N) 57.56 57.56
Mms (grams) 309.2 309.2
BI (T/M) 12.37 22.96
No (%) 0258 .223
Re (ohm) .9 3.6
Sd (M2) 0.513 0.513
Xmax (mm) 25 25
SPL @ 1W(dB) 87.32 86.67
RMS (watts) 4000 8000
Peak (watts) 8000 8000
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
