Overheating
A cap won't help voltage at all just current, the size of the battery and alternator will determin you're voltage under heavy load. Check the DC voltage at the battery terminals with a DMM when the system is bumping to see how low you're voltage is dipping, 14 volts with dips down to 11 while the engine is running is normal anything below 11 volts hints that a stronger alternator may be needed.
A DMM is a digital multimeter(if you didn't know).
I think you're worrying too much, if the amp is working fine and not cutting out then everything is OK.
That amp will have a thermal protection circuit in it that will shut down the amp as soon as it gets too hot, since you have not mentioned anything about it going into thermal protection I assume it must be running within specifications.
jLblazer620
jLblazer620
Long Island, New York
jLblazer620
michigan born
    May 14, 2026
michigan born
    May 14, 2026
