overheating amp
draegonaudio
got a small problem, i have a 1000w kenwood amp powering 2 jbl 12's that are 500w max, i have the subs connected on mono. now when i have the bass up for an extended period of time, the kenwood has a protection switch that will automatically turn off the power until the amp cools a bit, i want to know how to keep the amp at a descent temp so it doesn't shut off, it's very annoying at times. especally trying to show off driving by a group of girls on the street..haha
You need to see how high your gain is turned up if it is past 3/4 turn it down to 3/4 or less if that doesn't work try putting a fan on it or mount it in a cooler place
it already has a fan built into it, but it is a possiblitly that the gain is too high,
i'm drivin a '94 escort hatchback and i have it mounted on my back seat and i always got it folded down so i don't know anywhere else that's a cooler spot
All I can say is that your gain is probably too high.Just point the gain arrow at 10:00 and the hertz at between 70-80.If your a bass head then turn up the bass boost in the amp and I'm guessing this the excelon kac-x401m.
Take it easy and I hope I help you a little bit.
IT sounds like you have a prolbem with the ohm load going to the amp. You said you had two subs wired in mono. If they are 4ohm subs that means you have a 2ohm load at the amp. If you have a 2ch amp bridged into mono then your amp would see half of 2ohms. That means you are down to 1ohm. I don't know any kenwood 2ch amp that is 1ohm stable. You need to wire your subs so that they are 8ohm when wired in mono. This would take care of your overheating prolbem.
if you still have a problem with the amp overheating after trying some of these other suggestions... one more thing you can do is raise the amp off of the mounting surface about 0.5 inches. this will allow air to circulate around the entire amp and aid in cooling. this can be done by putting spacers or legs between the amp and the mounting surface. short plastic tubes around the mounting screws work the best.
are the subs single voice coil or double voice coil and what is the ohm rating of EACH voice coil? tell me that and i can give you a diagram to follow.
ok the complete specs on the speakers:
make: JBL
model: LC-S1250w
power handling: 120rms, 480 peak
sensitivity (2.83v, 1m): 93dB
frequency responce: 38Hz-500Hz
theile and small parameters
nominal impedance: 4Ohms
revc: 3.45Ohms
Fs: 27.4Hz
Vas: 109 liters
Qms: 3.18
Qes: 0.37
Qts: 0.33
Mms: 109.23g
Levc: 2.23mH
whatever the relevance, i have the two 12"s in a type 4 bandpass enclosure with a plexiglass window and 3 ports on either side of the
subs, in the chamber of the box, the subs are positioned in the shape of a "V". and i believe they're only single voice coil, but as far as
how many Ohms "each" coil is, i'm not sure, i might only understand half of those specs but hopefully they help out
thanx for all the help so far, i appreciate it
as stated in a previous post, you need to wire the subs in series to create a 8ohm load and then by bridging your amp it will "see" only half of that, meaning 4ohms. for a diagram click on the link under my signature and look at page six for diagrams. you will need the 3rd diagram on the page- "wiring 2 single voice coil subs in series".
ok, just an update , i did wire the subs in series and i had the frequencies at 80hz, and the gain at 10 o'clock, and the bass boost up all the way at 12db.........there was practically no bass at all, it sounded like a pair of 6x9's so i wired the subs back to the way i had them previously. are there any suggestions as to any other wireing configurations i can try to get the most bass out of my subs w/out overheating the amp?
the model is kenwood 1000w max kac-929, i'm at school right now so i couldn't give you the complete specs until i get home, i don't know them off the top of my head, so i'll let you know, unless you already know the specs on this amp
now that i know what amp and subs you have... here is the deal. you are reading too much into the 1000w badge on the front of the amp (that is not going to happen). the amp is rated as follows: (460x1@4ohm) or (230x2@2ohm) or (150x2@4ohm). since you have two 4ohm single VC subs rated at 120w RMS you should wire your subs in stereo which would give them 150w RMS each and give your amp a 4ohm load per channel. with this wiring scheme all should be well, good sound and a cooler amplifier temp which will prolong its playing time as well as its life expectancy.
draegonaudio
draegonaudio
jim thorpe, PA
A-hole
