overheating amp
yea, that's the original way i had it and i got just a little less bass with the wiring configuration that i got now, so i think i'll switch them again, thnks for your help...........oh one more question....why would they advertise for 1000w if it doesn't put out that much?
its a MAXIMUM wattage obtained in a laboratory, probably for a millisecond just prior to the amp frying to ashes. all the lesser capable amp companies do that to make it look like they have a killer amp for less $. cya.
that kenwood amp is 1000 watts max I would bridg it to one chanel then wire my subs to 8 ohms, or just hook up one sub at 4 ohms. If you dont know how to wire in series then : +to - to + to - : positive to positive one amp, negitive to negitive on amp. There should only be two wires going to amp. that will add the ohmic vaule together.
draegonaudio
draegonaudio
jim thorpe, PA
A-hole
