Orion xtrpro 2400 info please
Orion XTR 2400 Pro
1 x 1200W @ 4 ohm
1 x 2400W @ 2 ohm
THD:
Freq. Response: 20Hz ~ 250Hz (+/-3 dB)
S/N Ratio: >85dB
Damping Factor: >400
Max. Current Draw: 300A
Dimensions: 25" x 10.25" x 2.25" (63.5cm x 26cm x 5.7cm)
http://ampguts.realmofexcursion.com/Orion_XTR_2400_Pro/
Nice, pre buyout quality.
Im predjudiced, I love the older well made amps better than the cheap offshore tin covered garbage that seems to be all that most recent amps are.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I'd take the XTR Pro. They put out great power, are really effiecient, and just look better than the newer chrome amps. I have a Pro 1000, and it looks great. Haven't installed it yet, but I will have a review up when I do.
Those older orion amps put out a lot of power at 2 ohm. I the only thing I hear is that if you try to run it below 2 ohms you are asking for smoke. I have an Orion XTR 1400 but I have not hooked it up yet. I would definately choose the 2400.
it depends on which amp you are running. The Pro 2400 is only rated as 2 ohm stable. Run almost any amp below it's rated stability, and you will eventually damage the amp.
Good point but a handfull of amps are able to run well below their rated ohm load for long periods of time before death comes.
SWEET06CAMRY
SWEET06CAMRY
SANTA ANA CALIFORNIA
mr_malina
