Orion Amp Ground
boulderbronco
I have an Orion 900.2 that I will be using for my 12" subs. I will be running it at 2ohms 450 Watts per sub. I want to give the amp 4 gauge power and ground inputs but the connectors are for 8 gauge. That to me does not seem to be enough wire. Is there any 4-8 gauge reducer for such an application. I will be running a total of around 1500 Watts for the whole system so I am running 1 guage main wire to a distibution block. Also can I run a 1 guage ground directly to the battery? I have always gone to the body but I feel like a direct connection to the battery would be better. The body is not as good a ground as the frame would be. I don't want to go through the body to the underside where the weather can get to the connections. Thanks.
well you can use a distro block for the grounds and use 1/0 wire to 8 or whatever you need. if your amp only accepts 8 awg wire then that will be big enough for the amp. and you should keep your ground wire under 3 feet.
Yeah I am running the 1 AWG to a positive/negative fuse block right by the amps. I agree on the 3ft. rule but I just feel like the body is not the best ground. If you are familiar with how the body of a vehicle is mounted to the frame it is not a direct connection. I think I may go through the body and grommet and seal it real good and connect the ground directly to the frame. Sand it and clean it real good with a solid bolt. Then use some liquid tape and cover the connection real good to seal it from the weather.
boulderbronco
boulderbronco
Boulder
boulderbronco
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
