umm notice that he told me what to do at 11 this morning... i have tried this stuff.. needed to do big 3 anyway... so dont just immediatly assume that i am not takin advice cuz i am.... i took sblazers advice last night on AIM and too hccafans advice today and all with the same results.... im taking all the advice i can get. so instead of assuming im not taking advice how about helping me?hcaa fan just told you what to do......if I were you, I would take that advice and use it......................................
intelliq 1/4thlpf-35hz or so
hpf- like 90hz
gain 1/4 or a little above
12/full/24- 24
i guess the big question is can RLPS even handle this kind of power?
I take it the hifonics was a 2channel ab? Orion should quite a bit more efficent. Enough so to make double the power off the same electrical system, dunno bout that one.just did big 3... but now i prolly need to get an new alternator.... if i am running it at 2500w at 1 ohm and it doesnt have the power to get there, would it run as good as my 1000w hifonics if i put it a 4 ohm load at 1200w with my subs? im just not getting any output at 1 ohm... i dont know what the deal is... they move... but no output... any suggestions?
just another way to say itsince your not very good at listening, let me point out where you are going wrong. then maybe you can have bass.
see lpf, you have it at 35 hertz.
see hpf, you have it at 90 hertz.
that means you aint supposed to have any bass. your low pass is where you want the bass to cut from midbass, so turn that to 90. your high pass is used as a subsonic on this amp, so turn that to your port tuning, 32 hertz or so. that way it will play the freq's between that range, but your setting now it shouldnt be making ANY sound. do what i said and you will benefit from it. keep arguing and it will show this forum your lack of skillz.
