orion 2500D concerns
15nissen
Wealth of Knowledge
i bought a 2500d for kingofdaparkinglot.......its great and im quite happy. my problem is that i cant even blow a 50amp tube fuse? could this be that i still only have 4 gauge wire and its choking the power supply down. its louder to the ear for sure, just thought that was wierd. im running the amp at 1 ohm with a rise of 3ohm or so... it has duel power and ground inputs. when i do go to straight 1/0 will that make the difference?
do you just want to blow the fuse? is there a problem? is it not putting out the correct power?
if its wired at 1ohm and wont blow a 50 amp fuse its obviously not putting out any sory of power....the 50amp fuse is what i compete with at meca shows
They put out AC voltage... cmon, every CA.com guru knows that //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
smartass //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
josh dont even bother, maybe he means sumthin different than u think, i hope
i hope so to //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I think you missed my point? Voltage alone means shyte without an actual load.
And the 2500d cant even put out 150 volts, lol...
No, I got your point. And yes I realize they arent going to put out 150v.. I was just suggesting that if he got himself a DMM and checked the terminals, they might be putting out some crazy low numbers... Just a thought.
And just for my personal information, is it possible to figure out the actual impedance that the amp would see?
15nissen
Wealth of Knowledge
15nissen
Chicago
dkguitarist
