Optima blue or yellow top for audio? Which color??
swollen_cu
I am adding this as a second battery in the trunk, and undecided on the BLUE or YELLOW top optima battery. Which color optima would be best suited for car audio system and a brief description why would be appreciated. Already have upgraded electrical. Any suggestions? Thanks in advance
The yellow optima is specifically for car audio. The cranking amps is 750 but all are underated. IT should be around 850 to 900 cca. Mine i have had it tested and its cold cranking amps is 1126 So i have left my system on for almost 9 hours without the truck running and i went to start it and did not hesitate one bit.
blue and yellow optima batteries are the same except for the post. taken from optima's website;
The difference between BlueTop and YellowTop deep cycle batteries is that BlueTop batteries have both automotive (SAE) posts and threaded posts, while YellowTops (other than D31T) only have SAE posts.
Any more suggestions? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Johnson controls makes Optima batteries now. They also make most of the auto parts store and chain store brands. You will be just as well off...
952
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
879
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
You've read an outdated book...most of us learned things by either trial and error or someone more experienced helping...not a 20+ years old book 🤣🤣🤣
swollen_cu
swollen_cu
New Orleans
swollen_cu
    May 12, 2024
Brendon Jenness
    May 11, 2024
