Opinions on speaker enclosures?
^^^that. I saw them online at Crutchfield. They seem more for protecting the speaker from dirt and moisture. The idea seems ok for sealing off the back wave(if they weren't made a foam I guess), but they look like they fit real tight to the speaker, noting someone's comment about needing certain air volumes behind the speaker?.....Just wondered if anyone has pondered the idea of using a sealed cavity like that to place there door speakers in.
Again, placing a speaker that is designed for infinite baffle into a small sealed space can only hurt its low frequency extension. This includes those foam 'baffles'. Most people in the know who use those, cut the back/bottom out of the 'baffle' and use it simply to protect the speaker from water dripping down off the windows/seal during rain while still allowing it to utilize the entire door cavity.
I actually bought those foam baffles from Crutchfield to use in the door of my Civic. They took away all the bass. Bare in mind i did not test the speakers before the baffle as i just got them as an upgrade.(memphis 6.5)
So i cut a hole in the underside, a couple inch hole using a hole saw, i still thought it cut out the bass cause the OEM's had better output. Since i paid for the darn things, i got nervous about cutting the hole bigger thinking i'll make it sound worse or something, so i stuffed a little polfill behind the speaker and left it.
so actually, their probably better off without baffles. find a peice of plastic to protect from water as those baffles are way too much for their worth.
ive heard of guys using margarin containers as "baffles" to keep water and grime from getting on the speakers. ive also heard of guys ghetto rigging a pair of margarin containers together as an aperiodic baffle.
im actually planning on building an enclosure for a pair of woofers on my door panel. but had some questions regarding the wiring...
Pataforce8
Pataforce8
Amarillo, Tx
Mr.B
