opinions on ford 460 motor
btlking
Registered User
what do you guys think of the ford 460?
i just bought one and want to put it in a fox body mustang i can get the ****** and new springs and such as needed but is the 460 a good motor?
i got it on a steal and only need to replace the oil pump so either way im going to use the motor just wanted to know if it would be good in a fox body
People have put the big block in foxes but that motor weighs a TON compared to the 302 or 4 cylinder that came in the car originally. You would probably be better off to try and get a 351w and build it up strong. The only downfall would be the 351 wouldnt have as much torque. But the weight almost overcomes it especially if you are planning on leaving the stock iron intake (if its carbureted) and iron heads on it.
You will be quicker w/ a stroker motor. The 460 is a beast but it is heavy and performance parts are harder to come by. The 460 will make a ton of TQ though. If your just looking for a toy, then build the 460.
btlking
Registered User
btlking
Uranus
lrgnation
