Opinion about Hollywood subs.
I've wanted to keep clear from this post.. but since I've worked a good bit with hollywood subs... I might as well...
Hollywoods are cheap woofers.. They do fine with low power, and novice type installs.. If you want any type of power handling, you gotta keep em sealed... the suspension isn't very suited for high power ported use.. We've turned a many inside out with moderate amounts of power, and typical SPL ported boxes...
Our team used to run a good bit of hollywood stuff.. but we quickly found out almost everything else we tried, piss pounded them..
Just off the top of my head... Memphis HPs, IDQ's, W3's, Shiva's/Tempest's, ED K's, SE's, X-ones, 3500's, etc....will murder them in any box.. any install, any amount of power...
and I farted..
Loyd L.
Originally posted by bigbassman I've wanted to keep clear from this post.. but since I've worked a good bit with hollywood subs... I might as well...
and I farted..
Loyd L.
Bigbassman, I've never stated that the HSL were suited for the big ported boxes, in fact I've always suggested sealed. Any figure that I stated was always noted as being sealed. We've had no problem running them with high power. As far as making the statement that they were better than xyz brand I did not I simply said that you can pay less and get a sub that performs pretty **** good! Now about them being cheap woofers, well that's your opinion of which you are entitled too
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by bigbassman Hollywoods do fine with low power, and novice type installsLoyd L.
Originally posted by bigbassman Just off the top of my head... Memphis SHPs, IDQ's, W3's, Shiva's/Tempest's, ED K's, SE's, X-ones, 3500's, etc....will murder them in any box.. any install, any amount of power...
thank you for confirming what i said abou 10 pages ago, Lloyd......now ill you listen darkie?//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Originally posted by jtmoney thank you for confirming what i said abou 10 pages ago, Lloyd......now ill you listen darkie?//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
No, just because he agrees with your view still doesn't make it any more or less valid!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by DARKHART No, just because he agrees with your view still doesn't make it any more or less valid!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Apparently you do not realize whom Loyd is exactly. Let's make this clear that he is one of the most knowledgeable spl guys in the business. I have learned some from him even and know he knows what he is talking about when it comes to spl. Get a grip that you were proven wrong and move on with it. If it is your opinion and you like HSL's by all means go witht hem, but do not try to take that opinion and make claims against it that can be disproven and then get upset when they are proven incorrect.
Originally posted by Alaxan Apparently you do not realize whom Loyd is exactly. Let's make this clear that he is one of the most knowledgeable spl guys in the business. I have learned some from him even and know he knows what he is talking about when it comes to spl. Get a grip that you were proven wrong and move on with it. If it is your opinion and you like HSL's by all means go witht hem, but do not try to take that opinion and make claims against it that can be disproven and then get upset when they are proven incorrect.
First off, who he is is of no concern to me, Second, I never questioned his knowledge or anyone else's about SPL. Third, I too have even learned a thing or two from reading his post so I have no doubt that he is pretty knowledgeable.
As far as being proven wrong, what was I proven wrong about?.... Any statement that I made about any score, I can prove, in fact I even named people and places. So that proven wrong statement is a bunch of b.s .
Show me what claim that I made that was disproven!!!! Just because Loyd said so, is that your claim of being disproven????//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif :rolleyes: Get Real!! But then again on this forum I have noticed that Loyd is GOD, which is fine, I have no problem with that because it's your opinion.
It's really funny how my opinion on a speaker I like has turned into such yayaya mine is bigger than yours thing that all started with JTMoney and his views. Even that started out civil, but now I see that if anyone doesn't BOW DOWN to the running beliefs of this forum then all types of individuals will come out of the wood-works to smight thee! Well hell's bell's boys I'm shaking in my boots! I guess disagreeing with your "deity" has know made me an anti-christ or something even worse an OVERPECK co-conspirator......uaaagh!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Hot **** boys I've really gone and done it now...ha ha ha ha!
Originally posted by jtmoney exactly that! put money on it - take any sub u want - ED, sHoCkEr, Stroker, DD and give these subs 100RMS. now give an eXcursion this amont of wattage and it will outpound all those subs mentioned - eXcursions bump off ver little wattage, and for he money its a great budget SPL sub.
thats because the subs u just said are high wattage subs and not suppose to be used on a 100wrms amp, hmmm, now how the fuk u gonna compare them????
Originally posted by KurupT thats because the subs u just said are high wattage subs and not suppose to be used on a 100wrms amp, hmmm, now how the fuk u gonna compare them????
Now how the fuk u gonna compare them!!!! I suggest before you jump into an ongoing spiff:D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif You at least know what the hell you are commentting on. I never said that they weren't meant to be used with low power like 100wrms.... I said that they WEREN'T meant to be used ONLY with LOW POWER, I said that you can use high power on them as well, I also said that some of the cars here use in excess of 1000wrms on them without falure. Again before any of you try to quote me at least get it right....
If you can truely "PROVE" anything I said as a lie or false then I will apologise and say nothing further about the matter......//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
Originally posted by DARKHART If you can truely "PROVE" anything I said as a lie or false then I will apologise and say nothing further about the matter......//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
i didnt say that anything was a LIE, i was just saying how can u compare them at 100wrms, because that isnt shit to compare at, exspecially when u put shocker in there and they wouldnt hardly move with 400-500watts, i didnt mean to piss you off or anyting i was just asking a question on how u compare them at that wattage, because i know many people would compare shit at 100wrms cuz that wouldnt mean shit, its like running 6 1/2s
mike
Originally posted by DARKHART Now how the fuk u gonna compare them!!!! I suggest before you jump into an ongoing spiff:D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif You at least know what the hell you are commentting on. I never said that they weren't meant to be used with low power like 100wrms.... I said that they WEREN'T meant to be used ONLY with LOW POWER, I said that you can use high power on them as well, I also said that some of the cars here use in excess of 1000wrms on them without falure. Again before any of you try to quote me at least get it right....
This is what was disproven................and as far as Loyd being a deity? I am the one whom had my status as god for a while. I simply respect his knowledge in the field and as I CLEARLY stated in the post before hand. You are entitled to your OPINION. If it is disagreed with then fine and so be it. You are the one now being childish.
Originally posted by Alaxan This is what was disproven................and as far as Loyd being a deity? I am the one whom had my status as god for a while. I simply respect his knowledge in the field and as I CLEARLY stated in the post before hand. You are entitled to your OPINION. If it is disagreed with then fine and so be it. You are the one now being childish.
Alaxan, you are right, I did just act childish and for that you and the previsious poster please except my apology, that outburst was uncalled for. I still don't understand your statement as to what was disproven.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
Originally posted by KurupT i didnt say that anything was a LIE, i was just saying how can u compare them at 100wrms, because that isnt shit to compare at, exspecially when u put shocker in there and they wouldnt hardly move with 400-500watts, i didnt mean to piss you off or anyting i was just asking a question on how u compare them at that wattage, because i know many people would compare shit at 100wrms cuz that wouldnt mean shit, its like running 6 1/2s
mike
KurupT, I owe you an apology, I took your statement the wrong way and I'm sorry I responded in that way...:eek: :eek:
I never compared the HSL's to anything at a 100wrms, I'm not sure were that power comparison came from but it wasn't me. As far as power goes I simply stated the type of power that we run on them.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
Also note that I never said that the shocker's, dd, re's , or any of the other brands that are popular on this forum, were bad subs. All that I have done is defend HSL as a brand that wasn't "crap", and a brand that I like and one that wins at show's and don't cost an arm and a leg. I do believe that it was "others" on this forum that started the product bashing and even then I still never called their brands "crap" or even down played them in any way! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i think moderators (if we had any //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif ) should have locked this post by now........
DARKHART
One Hitter Quitter
DARKHART
LITTLE ROCK, AR
jtmoney
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
