Only using 2 ch on a 6 ch amp
ekincam
I have a JBL GTO 755.6 amp. This is a 6 channel amp; 4 channels are full range, and 2 are for subs only. Presently, I only have Arc 6000 component set installed and have them bridged so that they basically take up all the full range channels. I currently do not have a sub installed so the 2 sub channels are open.
I have had the amp running this way for a couple days. Is it safe to continue using the amp with the sub channels open? I do intend to get a 10 or 12 in a a month or two.
The amp is connected to a Premeir 860 and the gains are turned all the way down. I have the sub output switched off in the settings on the 860.
ekincam
ekincam
SoCal
nismos14
