Only one sub works, help
Headies
I have two type-r's each powered by their own 2 channel amp bridged. I originally had 1 amp and 1 sub and it hit hard. I added 1 more sub and 1 more amp. But now, only one of the two are hitting. The other one doesnt move.
This is how it is setup:
The second amp in the series is the only one that powers a sub right now. Sub 2 would hit and sub 1 wouldn't move. I switch the speaker wire from amp 2 to sub 1 and it hit, while sub 2 wouldnt hit with amp 1 speaker wires. I don't know how to set this up or fix the problem.
I have the RCA's coming from my deck to one amp, and another set from the first amp to the second. The subs only respond to the second amp in the series.
Which amp did you add recently? Number 1 or 2? Is it the one that doesn't work?
Have you checked the power and ground wires for it?
The power and grounds are fine. I switched the power from the d-block and the other one worked. Could for some reason the d-block only send power through one of my 8gauges?
It could if the resistance were great enough ... that would be a really odd scenario, though ...
To clarify ...
Sub 2 + Amp 2 = Sub 2 hits
Sub 1 + Amp 1 = Sub 1 doesn't hit
Sub 2 + Amp 1 = Sub 2 hits
Sub 1 + Amp 2 = Sub 1 doesn't hit
Correct ?
If that's the case, it's probably that sub 1 is damaged ...
i think that is what he was saying. As of lately, I have had a hard time deciphering what a lot of people are trying to say.
.Check your rca's. Try switching your RCA's on your amp. go from HU to output. then, input to output.
to see if your sub ever works if you have a 3 output hu just hook to front or rear. I dunno though.
EDIT: Just found the fuse part. Try switching out the fuse or get a new 1.
^^Still try what I reccomened though.
Headies
Headies
Aurora, CO
Silver
