thegreatestpenn
lazy genius
- Thread Starter
- #46
the voltage regulator is built in to the alt so if its a regulator problem its still an alt problem. looking at ho alts now, what u guys think of this:It's clearly a bad alt, bad alt turn on wire, or a bad ground. If he ruled out his grounds and load tested and it stayed started until he turned an accessories on, that tells you that the alternator was turned on by the turn on wire, but it wasn't charging at a high enough voltage. An alt swap out will tell you if it's the actual alt or a problem with the ecm. The ecm monitors engine temp, rpm, etc. If something is amiss, it will basically turn the alt off or it can turn its output WAY down. One of the voltage modules would probably bandaid the problem.
Honda Civic Alternator 2001-2005 1.7 L 145 AMP : eBay Motors (item 260581452691 end time Jul-05-10 08:12:03 PDT)
