thegreatestpenn
lazy genius
So about a week ago, i took my civic in for service and they changed all my belts, including the belt for the alt. Today while i as playing my system at full tilt (i rarely do so I was checking voltage) i noticed my voltmeter reading upper 11.xxx to low 12.xxx. I thought it strange so I paused the system and the voltage only got up to the upper 12.xxx. So I'm thinking the voltmeter might be bad, or my 2nd batt's ground. So when I get home I check the voltage, come to find out the car is only charging to 13V at idle with no electrical accessories on nor the sound system (in my sig if you're wondering). This has me puzzled, I used to always idle at 14.5V give or take .2V. Could the belt they put on be an improper size causing the alt not to charge higher? all help is appreciated.
I also cleaned the batt terminals up front to make sure they didn't have corrosion causing the problem.
