One sub
paul83085
Sub going to be powered by jbl 600 one good sq but i want to bump to still so need that spl. Want to spend under 200 bucks for the sub ideas probably a 60/40 split and give the addys for the websites too thanks
Originally posted by paul83085 Sub going to be powered by jbl 600 one good sq but i want to bump to still so need that spl. Want to spend under 200 bucks for the sub ideas probably a 60/40 split and give the addys for the websites too thanks
i would say re se, http://www.respl.com dont look at the msrp there around 170 or so for a 12
take your pick...
ED K-series
http://www.edesignaudio.com
RE SE (SQ not impressive, so I've heard)
http://www.respl.com (call for prices or pm teamPSI)
Adire tempest (15" SQ sub, you didn't mention the size)
http://www.adireaudio.com (pm jlaine for prices)
ok im going to get the 12O.14 and i see that it weighs 26lbs will the mdf be able to hand that or am i going to have to brace it and if so with what etc. How will i hook it up to what ohm etc and can i give it all of the 600.1 and it be ok??
The O series is ALL SQ.. no bump, according to people, although, only 2people have actually heard it.
And yes, MDF is good enough for the biggest and meanest boxes. 3/4" for 1000w and below, 1" for anything over that. (that's what I was told) and yes, braces are always a good thing. Less flex, more SPL
ok and the k is the split...that one is only 20lbs so still brace it?? guess it would hurt it...um can i give that the full 650 ish watts from amp or what?? are there numbers underated and about how long will it take for it to get here?
Originally posted by paul83085 ok and the k is the split...that one is only 20lbs so still brace it?? guess it would hurt it...um can i give that the full 650 ish watts from amp or what?? are there numbers underated and about how long will it take for it to get here?
if u have the money abd room...get 2 10" or 12" k's! My current setup is 2 12" k's and a jbl 600.1 w/ 2.5 cubes each tuned to 32hz. It'll be perfect...plus if u order now, u get 15% off...so that's puts u at $202 plus shipping which is $20 for ups ground. That'll hit hard and sound good doing it...i know from experience! peace
NG
p.s.- that is also my pref. 60/40 split
Originally posted by ngsm13 if u have the money abd room...get 2 10" or 12" k's! My current setup is 2 12" k's and a jbl 600.1 w/ 2.5 cubes each tuned to 32hz. It'll be perfect...plus if u order now, u get 15% off...so that's puts u at $202 plus shipping which is $20 for ups ground. That'll hit hard and sound good doing it...i know from experience! peace
NG
you have the old k's, not the new flat cone ones that are due to come out June 1st
paul83085
paul83085
USA
NDMstang65
BP1Fanatic
BP1Fanatic
