One Brahma 10" or two 10" W3's...
beachboy016
I was planning on getting two 10" JL Audio W3's in an HO wedge box being run off of a JBL 1200.1 amp. I have been hearing a lot of good things about Adire Audio's Brahma though. Which do you think would be better in terms of SQ and SPL. I would probably want to keep the same JBL 1200.1 amp to run the Brahma if I chose it.
go with the brahma....and then later on you could add another brahma if you wanted to....where as its a little tougher to add 2 more w3's....its possible but would be tougher to have 4 subs.
I have owned a pair of 12w3's, and a pair of Brahma 15's. My Brahma's require a nearly identical size box to the 12w3's. YES I know that JL suggests 1.5-1.75 for the 12w3's, but if you plot them out on WinISD you will see that they require a much larger box than what they say.
My point here, is that if you put the 12's in a suggested box, it won't sound AS good as with the bigger box. Typically, the smaller the box you put a sub in (compared to what they NEED) the sloppier it is gonna sound. So you could buy a Brahma 12, and put it in just under 1 ft3 (after sub displacement--so about 1.1 gross) it will sound MUCH MUCH better than a pair of 12w3's...and because of the design of the subs, the Brahma will do the low notes with a ton more authority than the w3's.
Truthfully, I would take a Brahma 10 over a pair of 12w3's any day. Port the Brahma in the right size box, tuned to the right frequency, and i think that it would walk all over the w3's in quality, and probably keep up pretty well with the w3's in output too.
Eric
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
6
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
8
beachboy016
beachboy016
Los Gatos, CA
beachboy016
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
